ICON coil overs any good??? - Ford Powerstroke Diesel Forum
Old 06-24-2012, 06:43 PM
looking for a suspension upgrade and found coil overs for $1600
are these any good???
Rock And Roll Offroad Store
Old 06-25-2012, 08:44 AM
All honesty upgrading to coil overs on that low of a lift will actually net less travel. If you are not worried about travel then no biggie.
Old 06-25-2012, 10:43 AM
Yup,
These trucks already have limited travel up front so putting in a coilover that doesn't use a complete replacement tower would most likely result in the same or evenless travel than stock.
Old 06-25-2012, 09:17 PM
so they are not a good idea
will it make the ride better if I'm not worried about travel
Old 06-26-2012, 07:24 AM
It takes some increased travel to improve the ride on these trucks.
Technically coilovers don't ride any better than a comparable standard coil and shock combo. It all comes down to spring rate, shock valving, and geometry. Wheel and tire choice also play a big role on ride improvement.
Old 06-26-2012, 07:49 AM
so whats my best option on suspicion if my budget has to be under $3,000
Old 06-26-2012, 10:30 AM
I would call up Marty at Truck Toyz Performance and talk to him. Tell him what you got and how much you would like to spend. He is a no nonsense kind of guy too...
Lift Kits, Truck Suspension Kits, Truck Lift Kits | Truck Toyz
Old 06-26-2012, 04:38 PM
alright thanks
Old 06-27-2012, 01:33 PM
Assuming that you are wanting to go a little taller since your original post showed coilover for 4-6" of lift I would suggest the Carli Backcountry System.
Carli Ford BackCountry 2.0 System
They will have some 2.5 kits out in the future but they are still testing coil rates and shock valving.
Pure Performance has some very nice 2.5" systems that would fit into that budget as well.
Old 06-28-2012, 07:04 AM
Feedback Score: 5 reviews
Coilovers won't ride better than a coil-shock if the spring rates and valving are the same..X2 on available travel.
Tags
carli, coilovers, icon, rock n roll, suspension
