I'm in the process of mounting a set of procomp traction bars on my 2006 crew cab short box with a 6" lift, since I just destroyed a set of leafs and the rear section of my driveshaft. The issue started when I was about to drill the holes for the front mounts. The passenger side was no issue, but on the drivers side the fuel tank is so close to the frame I cannot get up there to move the lines running inside the frame. Anyone else have this problem, how did you fix it? Any help would be great.
