Im try to search some information ,
To see how tall , or how big I can lift my 2006 , f350 crew cab , long bead . But I only found a leveling kit . I don't know if the parts fit the same . For the 4wd . Then the 2wd. Thanks . ![]() Any info .? Last edited by Jdmdomo; 06-18-2012 at 08:43 PM. |
Parts are way different! Fabtech makes a 6" lift for our 2wds.
www.fabtechmotorsports.com-basic kit www.fabtechmotorsports.com-performance kit Oh, and if you go with a leveling kit, make sure you get the metal spacer, not the poly one. The poly one sags under the weight, then the extender bolt will break because of the play in the spring. Been there, done that, bought the t-shirt...
Oh, if you find yourself having to replace the rotors, know that they are rotor/hub assemblies, not just rotors.
Knuckle with axle spindle ![]() Front of rotor/hub ![]() Side by side: 4wd rotor & 2wd rotor/hub ![]() Ford sold me the wrong part, imagine that... |
Thanks .
I think I need to reaplace , The Axle spindle too . Cuz I ear some wierd noise . When I drive . Also . Your truck. Looks really nice . Well the only modification I have its some 20" Xd series , and some Led's I dont have to much time with my truck . I boutgh it like 2 months ago , Looks like a company truck . |
Im fixing it little by little .
Its a 6.0 turbo diesel . As the check engine light also . Im oready check what it is , with a scaner of course . And they tell me ..its the injector number 6 .. Also the sensor .the one its on top of the pumpkin., on the rear diff . I dont know if that cause me not to read the speed . On my cluster .? but im looking for some other parts also .the wants make my truck looks better,. its my first diesel truck .so. |
Fabtech , say' s it's only for the v10 diesel engines ,
Mine it's a 6.0 |
Sent from my iPhone using AutoGuide.com Free App |
You need the one for the v-10/ diesel. the v-10 is a gas motor but is similar in weight to the 6.0 so they require a little stiffer spring unlike the 5.4 gas motors.
