leveling kit help please - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-17-2012, 06:02 PM Thread Starter
I want to put a leveling kit on my truck, just a 2-3" front end lift...
I have a 1999 f250 Superduty XLT Extended cab 6.8l V10(should be same as the 7.3 stuff) with twin I beam suspension 2x4.
My problem is... i can NOT find ANYTHING that will work. i wanted to get the coil spacer that go on top with stud extender but everywhere i look it says wont fit XLT or extended cabs..... i looked around for extended coil springs.. cant find any. some1 said heavy duty coil springs.. cant find any that will raise truck any.
I have no idea what or how to raise the front. The truck is raking 4-5" so i BADLY need help cause its just raking horrible
Please help..?
Thanks
^^^ Rake action ^^^
hunter3014 is offline
post #2 of 3 Old 06-18-2012, 06:39 AM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
Are the front springs the same diameters as the 4x4 ones... i have an old set laying around off a 2005, if the the upper and lower diameters are the same it may be slightly longer to give u that lift ure looking for. They are the 4800lb springs off an ext cab short bed
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #3 of 3 Old 06-18-2012, 09:47 AM Thread Starter
you know, i really dont know. i could measure around it and see? i also can add some pics..
