Leveling Questions
I am quite the newb when it comes to leveling kits and have a couple questions. My truck sits 41" from fender to ground in the front and 41.5" from fender to ground in the back currently. I am a 1/2" off of being level but most leveling kits are for 2-2.5". Is it really just a 2" lift?
A lot of the leveling kits also just seem to be either coil springs or coil spring spacers. Can I just buy new coil springs and new shocks a make a kit myself? What other components are required? Do I need a new track bar? What will I use to fix my caster alignment? Any info would be great guys. My shocks are currently garbage. I bought the truck a couple months ago and it still has what appears to be the original shocks on it (115,000 miles). I was looking to do just a small lift (2-2.5") now instead of replacing shocks all the way around and lifting it in a year or so. Thanks for the advice! Rich |
bump!
I could use this info too! |
bump!
Sounds to me like the truck has already been leveled. 1/2 inch difference is probably just spring sag. Stock and empty the rear would be about 2" higher than the front, and loaded to capacity would sit about level.
If you're that concerned about 1/2 inch, you might put something on you can adjust as your springs sag. Air bags or some type of shim maybe? |
I'm wondering if the Harley's ride higher in the front from the factory? Just picked up a 2010 Harley F-250 a recently & after measuring last night, I am around the same height as the op - 40 3/4 front & 41 1/4 rear. It has not been leveled or modded at all. With 275/65/20's
If the Harley's are 2" higher from the factory (springs or?), I am now wondering if there would be any adverse effects from a leveling kit? |
A levelling kit is just a lift kit for the front only because most trucks come from the factory 2-3" higher in the rear. My F-250 was 2-1/2" higher in the rear so i originally put a 2-1/2" levelling kit on it which worked fine!
Some trucks have the snowplow option (or maybe other options also) that come with higher rate front springs which will already make the front sit higher. If you are only going with a 2" levelling kit then you don't really need to worry about changing your trac bar, but if you go any more than that it would be a good idea. |
If the Harley's are naturally higher in the front of the truck would I need to order different shocks? I have noticed some shocks come +2". Just want to make sure I don't waste money on anything. I was looking at doing 2" coil springs but its seems my Ford coil springs have already taken care of that. I was then going to add Top Gun Customz Night Hawk shocks as they require at least a 2" lift in the front.
Would I be good to just order the shocks? Would after market springs give me a better ride quality? |
We have kits complete with whats needed.. new progressive coils will ride better but if your looking for a real improvement you need a 4 link kit..min lift 2.5"
Night hawks are Pure Performance's..just coated Black cary |
Could anyone please give the stock front ride height of a 2010 F-250, with the factory 275/65/20's? I'm trying to determine if my Harley is already "leveled" from the factory sitting close to 41" - before I decide whether to add an inch or two more..
Thanks |
What 4 inch lift with the 4 link system would you recommend for a truck that will not see much, if any, offroad use? I want a much smoother ride than I currently have. I need all new shocks all the way around right now and figured I would just lift it at the same time.
Are pure performance shocks decent as I like the look of them in the night hawks and want them to match the appearance look I am going for. |
