Ride-Rite, what would you do other than cu$$
I have a 2003 F250 CC 4x4 FX4 that I installed a set of Ride Rite 2330 airlifts on in the fall of 2008. The truck had 115,000 on it then and had 160,000 when I found the problem. I highlighted the FX4 for a reason.
This is the truck: ![]() This is the link to the installation instructions which I used to install the airlift system. http://riderite.com/site-resources/r...ation/2330.pdf Note Diagram "C" on page 3. Where it shows how to install for F250 FX4, also note that the directions were made/issued Aug. 2006. That is how the system was installed and I never had any issues with it and usually ran a minimal 10-12 psi in it. This is a photo I took when I was removing the system last winter - I was not only shocked I was pretty ![]() ![]() These are pics of the brackets after removed from the truck: ![]() ![]() the destruction/breakage is obvious. You can tell that the holes used to mount the brackets are the ones used in the directions. After calling the retailer and telling him what had happened he referred me to Firestone Tech/Warranty which I did and they responded with the following. From: rrtech@fsip.com Date: Thu, 23 Feb 2012 10:58:19 -0500 Subject: RE: Air Bag Supports This happened because the kit was miss-installed; the lower bracket was set way to high and caused the brackets to bend. You can order new brackets from SD truck spring and there number is 877-774-6473. I will also send you a copy of the install guide so that you can see how the kit was installed incorrectly and the install guide will have all the part numbers for the new brackets. Thank you Tech/warranty Because I don't know where he got this installation guide I took photos of it rather than a link, Note: bottom of page one to me appears this guide came out 07-11 where as my guide came out 8-06. Page 3 Figure "C" is what he is telling me was incorrect. These are photos of the instructions he sent: ![]() ![]() ![]() ![]() I installed them according to the directions I had laying in front of me when are the ones taken from the Ride-Rite website................ http://riderite.com/site-resources/r...ation/2330.pdf I have resent this information to their Tech/Warranty with no response as yet. What would you do if they hold their ground? Last edited by MadlockMo; 06-01-2012 at 08:10 AM. Reason: Added additional photos and info |
Do you still by chance have that manual? If so, dig your heels in. You were only doing what they told you to. I am sure that they are aware of the woops in the old manual that you used, and revised it....probably due to other failures like yours! Stick with it, it was their mistake, not yours.
Meat |
Dont let them get over on you. Fight them!
Tks guys, this is a pic of the instructions I used: (bottom left diagram)
Unfortunately you aren't the first person sending pictures in showing the same condition. I feel they need to correct their problem and offer an upgraded mount to all of you faithful consumers, if not they aren't the only game in town. Surely they will remedy this by new instructions and the parts needed.
Ask to speak to someone higher up. Try to talk with someone in upper management and explain to them what happened. A tech is just doing his job and will try to stop the issue at his desk without holding the company, the one that signs his checks, responsible. If all else fails your only other solution is to file a small claims lawsuit. Sometimes a threat letter from a lawyer works, sometimes it doesn't but don't let them get away with it which is what they are hoping you will do, kind of like an insurance company will do. You might call a lawyer and just ask them what your options are if the continue to decline your warranty issue.
Regards, Dwight |
no, its not right. but they have more money than you do. talking to a lawyer will cost you more time and money than the part is worth. ive been screwed lots of times, just learn to fight the battles you can win. imo, cut your losses and walk away.
bailey |
I have the same airbags on my truck and can see that your bracket was set too high, it should have been set so that the lower bracket was just barely above the factory jounce tongue that is part of the block.
I don't know if I still have my original instructions, but I can see that the picture (fig. C) does have the typo (F-250 FX-4) which is not the same as an F-350!!! But the instructions do state: "Some trucks will have a cast iron jounce tongue as shown in figure A. If this jounce tongue is present, the height setting of the lower bracket will be just above the jounce tongue (to clear the head of the bolt going up into the bottom of the air spring). If there is no jounce tongue, simply assemble the lower and saddle brackets at the shortest setting. See figure "C"." So you are only supposed to use the info in fig. C if your truck doesn't have the jounce tongue. I can see that the instructions are confusing because of the typo, but I don't think you are going to get anywhere with them by trying to push this issue very far because of the way their instructions are written.
Regards, Dwight Last edited by StoneGuy; 06-05-2012 at 04:03 PM. Reason: typos |
I just took the time and read the directions and you don't have the jounce which would require you to install it on the lowest setting possible and even though Figure "C" clearly shows the second setting for a FX4, they do direct you to install it on the lowest setting possible. Kind of a conundrum. Could be kind of dicey if you pushed this too far. I would try to move your concern up the management ladder and get them to admit the the FX4 setting was wrong. You would expect that their installation diagrams to be 100% accurate for obvious reasons including your own safety because it is possible for anyone to get the installation wrong and what point is buying the product if there is a chance to install the product incorrectly by following their diagrams which result in failure of the product.
Regards, Dwight |
