How high with just springs
Alright I've searched a bit both on here and Google and can't find the answers I'm looking for so I thought I would just ask you all.
First off I'm looking at a 2003 F350 crew cab long bed 7.3 6 spd single rear wheel 4x4 1. How high can I take the front with just leaf springs before other mods are needed ? (Drop pitman ect I do realize I will need New shocks though) 2. I am also planning to raise the back( level with the front) with leafs and get rid of the stock blocks ... Without trimming fenders could I fit 37-12.50-20s with this amount of lift or will I have to drop to 35s ? I don't mind spacing the bumper or trimming plastic just don't wish to hack my fenders ... And am I correct to assume I would need a 4.5" back spacing on a 9 or 10 inch wide 20 inch wheel to fit the 37s? As of right now the truck will see very little if any offroad mainly just want a better stance and look for now as I'm only home to drive it three days a month lol Thanks in advance guys and I apologize if this has been asked a billion times lol |
I wouldn't go much more than 2" in the front without touching the trac bar at least. you could probably get away with 4" or so before worrying about the pitman arm. I have the skyjacker add-a-leaf leveling kit which i got about 2" in the front with and i noticed a difference in how the truck steered (sluggish) and drove, not that it is horrible but just different. I didn't drop the trac bar at all but had a hell of a time getting it lined back up.. So to answer your question, I woudl stick with 2", maybe 2.5"tops unless you want to start dropping the trac bar and pitman arm. I am just running stock tires (265/70) but i think you could fit 35"s with a leveling kit, there is alot of empty room in my wheel wells. my truck is also an 03 7.3 6sp 4x4
First of all IMO, I wouldn't go higher then a leveling kit without changing trac bar parts and pitman arm.
I had a 6" kit that retained the stock pitman arm and trac bar. It has terrible bumpsteer and wandered all over the place. You will need atleast a 6" lift kit to clear 37s for daily driving. I have a 8" and when I'm flexing offroad I can still rub my fenders. |
Hmm I was really hoping I could go a little higher lol ... Might have to look into tracbar anf pitman arms hen thanks for the reply though
Ok so how how you feel I could go before driveshaft mods are needed? I figure the pitman arm and stuff can't be that expensive lol ...
Anything over 8" requires driveshaft modifying. Going higher than that will need crossover steering, and transfercase clocking when approaching 12".
Thanks for all the help guys .. seems this is going to be more trouble than its worth for just a temporary setup ... Think ill just ride stock height and tires and just start gathering the parts for the end goal of 14-16 inches of lift on 40-42s .... Again thanks for the help
