Icon or Carli 4.5" lift - Ford Powerstroke Diesel Forum
post #1 of 16 Old 05-14-2012, 06:49 PM Thread Starter
I am planning on lifting my 2006 F-350 cclb 4.5" I have been looking at the Carli performance 2.0 kit and the Icon stage 1 kit. I do not go off road with the truck ever, Don't tow very frequently with the truck, I do put 2000 ish lbs in the bed about once a month. I am looking for the best quality ride I can get without spending a fortune. I am thinking either way I'm going to convert the rear leafs to 2011 rear springs using PMF 08+ spring hanger kit. My concern with the carli kit is that if the rear suspension has that much travel which I'm sure makes it great off road, how will that handle alot of weight in the bed? Will the rear of the truck sag alot with that much weight? I am also thinking of using PMF 4-link either way also. Has anybody riden in trucks with both suspensions? I had an Icon kit in my 03 and liked it but I've read alot of good things about Carli. Any and all input is appreciated. thanks
mint-6oh is offline
post #2 of 16 Old 05-14-2012, 07:29 PM
wired1's Avatar
If you are going to be using PMF stuff, just have him build you a 4.5" kit. He can build it using icon springs. The 7" he built for me rides as good if not better then my icon 4.5" i had, but i think some of that is the shocks and 3 link. Give trevor a call you be surprised what he can do for you!
2013 F150 FX4 EcoBoost fully loaded with the app pkg on Icon 2.5" coilovers
06 F350 Lariat-PMF 8" on 37'sSold
09 F350 ccsb Pmf 7" on 37's Sold
01 F250 ccsb 6" on 35's with to much to list Sold
98 Cobra Vert 583 RWHP Sold
wired1 is offline
post #3 of 16 Old 05-14-2012, 07:42 PM
Clayton1985's Avatar
There are alot of choices/options and deciding on one is not easy by any means. Good luck on your decision!
It took me over a year to decide on size/brand/"stage" and decided on PMF.
2008 Job 3, F350, 6.4/drw/lariat/CC/LB, Spartan, Viper 5902, Line-X, Flo-pro egr delete, aFe stage 2 proguard 7, MBRP Cool Duals/downpipe/CAC, CCV mod, coolant filter PMF 7" 4link, Rigid Dually fogs, Royalty Core 3pc, Crown brake lines, Mishimoto Rad
6.4 Rebuild May/2015, BD manifolds+Uppipes, chromoly rods, rockers,lifters, hd springs
Monstir 20", 37x12.50 ATZ P3
1999 Corvette Cpe
Clayton1985 is offline
post #4 of 16 Old 05-15-2012, 04:32 AM Thread Starter
I've heard nothing but good things about PMF and Trevor. While I Havnt heard anything bad about icons ride and was very happy with my last truck with an icon lift , I read carli has softer ride due to Thier spring rate and shock combo. They do use a spring pack in the rear which I think would make it ride harder then just the stock spring with a block. Maybe I'm just overthinking this.
mint-6oh is offline
post #5 of 16 Old 05-15-2012, 08:41 AM
NotStock's Avatar
Originally Posted by mint-6oh View Post
...They (Carli) do use a spring pack in the rear which I think would make it ride harder then just the stock spring with a block. Maybe I'm just overthinking this.
Not necessarily. Just depends on what the spring rate of the pack is. Carli does very good with their spring rates and valving, so I would not be afraid to trust in their ride quality.
If there is anything we can assist you with, just let me know!
Precision Metal Fab
Trevor Hall
(520)465-7971
NotStock is offline
post #6 of 16 Old 05-15-2012, 09:34 AM
Skyd Ram's Avatar
Quoted: 150 Post(s)
I agree,
The Carli mini pack replaces the extremely stiff overload leaf so you get a better ride than stock and gives you some lift without needed to run even taller block. I have also found that it helps decrease wheelhop a bit.
The production mini packs for the 05-07 leaf are still a few weeks away from being available. Another option would be the Carli full leafs for the 05-07 trucks. It gives you some lift, a huge ride improvement, eliminates the need to run the factory block, and the relocated center pin moves the axle to middle of the wheel well for better tire clearance.
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Fox Shocks
Dynatrac | Flo Pro Exhaust| aFe Power | S&B | BMF | Fuel | Air Dog | Amp Research
Trailready Wheels | Spicer | ARP | REV-X | RIGID Industries | KD Fabworks | Baja Designs
888-886-2480
Skyd Ram is offline
post #7 of 16 Old 05-15-2012, 02:01 PM
6.0L Stroker's Avatar
I have the Carli backcountry 2.0 with the full rear springs on my 11 and the ride is fantastic. The rear springs do sag some when towing. But overall I am 100% satisfied with my kit.
2011 F350 CC/SB Bronze and Gold KR tinted windows, spray in bedliner. MBRP 5in filter back with 6in tip and Mini Max. S&B Dry Intake, TGC Dual Stabalizer.
Sold 2004 Ford F-350, cc/lb Lariat, Procomp 6.5 lift with 37/13.5/17 Toyo Mts, Id tuned Ficm, Bully Dog Triple Dog, MBRP all the way back,
6.0L Stroker is offline
post #8 of 16 Old 05-15-2012, 02:33 PM Thread Starter
Does it sag a lot with weight in the bed? Or just towing?
mint-6oh is offline
post #9 of 16 Old 05-15-2012, 03:22 PM
I'll be honest I haven't really hauled anything in the bed. Here's what I was towing. The samurais might be 5k total plus the trailer weight.
ID:	38038   Click image for larger version
post #10 of 16 Old 05-15-2012, 04:09 PM
Nissankidd's Avatar
Mint whats your price range. I'm not sure if swapping to late model springs would benefit you especially when you tow. I've added a leaf to my 11 to help with towing, the ride is firmer but I felt it was too soft from day one.
2015 F-250 platinum
Nissankidd is offline
