How hard to install a leveling kit? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-13-2012, 08:35 AM Thread Starter
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
I ordered a leveling kit(mini spring pack) for my truck. How hard is this to install? meaning, can I do it in my driveway by myself? or is it easier to do with help? mechanical ability is not an issue with me. Ive never even loosened the front u bolts on my truck or anything.
Those of you that have installed this type, how do you go about doing it?
Thanks in advance!
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #2 of 5 Old 05-13-2012, 09:15 AM
Betaracer's Avatar
Quoted: 15 Post(s)
It isn't hard at all. You should have new u-bolts with the kit, so if the old ones don't want to come off easily, grab a grinder with a cutting disc or a cutting torch. You will need to be able to raise the truck high enough to get the mini-pack in as well as the through bolt.
2016 F-350, FX4, CCLB, 6.7PSD, 7" OUO/ICON/FOX lift, 37x13.50-18 Toyo MT
Betaracer is offline
post #3 of 5 Old 05-13-2012, 12:37 PM
I second the "torch or cut u-bolts".
2004 F350 PSD
8" Icon, Loud Pipe, 58v FICM, Deleted, MudGrapplers, Edge Insight, Sct tuned by Vivian.
2011 F350 PSD
AFE , Airbags, Recon, BMF , Nitto,
20046.0 is offline
post #4 of 5 Old 05-13-2012, 12:41 PM Thread Starter
Doesn't Even Care
Quoted: 69 Post(s)
Through bolt, does that go all the way from the bottom of the spring pack to the top, or what?
Also, do I need to raise the truck high enough to get the front suspension to droop totally, then stick another jack under the axle to raise it until I can get the u bolts off. Then drop the axle enough to get the spring pack in? Is that the order I'm looking at?
Sent from my Acer Android Tablet
Nick
"The Mistress"
post #5 of 5 Old 05-13-2012, 01:00 PM
Remove front tires.
Jack front end of truck up.
Remove steering components from axle (trac bar, drag link) and shocks.
Put a jack under the front axle and remove u-bolts.
Lower axle until you can get those bolts that goes through the spring pack.
Install spring pack and reassemble.
Something along those lines
2004 F350 PSD
2011 F350 PSD
20046.0 is offline
