level or lowered? - Ford Powerstroke Diesel Forum
Old 04-11-2012, 05:38 PM
level or lowered?
i got my 04 2wd about 2months ago, i cant tell if they leveled it or lowerd it. iv never had one before and cant tell. everthing looks stock but im not sure..
Old 04-11-2012, 05:40 PM
Lowered.
They lowered it.
Old 04-11-2012, 05:44 PM
what did they change?
Old 04-11-2012, 05:47 PM
Not sure.
I would have to look at mine to compare but I am sure that it is not stock. They at least lowered the back and maybe even the front.
Old 04-11-2012, 06:03 PM
Looks like both.
Just measured. My front from edge of tire to wheel well is 9.5" and rear is 10.5" with stock 265/70/17 tires. I have air bags in rear for towing but they are not inflated. I was going to level the front when my original tires were replaced but unfortunately I had a an unexpected blowout on the truck when pulling my toyhauler and simply replaced them all with stock when up in the mountains. I will level it and get a slightly taller/wider tire next time I hope. I hunt so the taller would help in that terrain and the extra width will help when I go to the sand dunes. I do not want to do too much since I tow a heavy trailer full of toys.
Old 04-11-2012, 06:07 PM
i also have 265/70/17 and from edge of tire to wheel well is 6" both front and back
Old 04-11-2012, 06:09 PM
Might be different.
Just noticed, yours is two wheel drive. Mine is four wheel. I still think yours was lowered though
Old 04-11-2012, 06:15 PM
Nice Truck
What do you plan to use your truck for? Type of driving?
Old 04-11-2012, 06:16 PM
lol ya its 2wd.. does any one know stock 2wd size? or how i can change it back
Old 04-11-2012, 06:25 PM
Front should be lower.
Front should be lower whether 2wd or 4wd for sure. On a 3/4 ton I would bet the overall clearance is the same for both. They are made to tow. You usually have to look at the front axle on most trucks to tell if a truck is a 4x4 when stock because they typically sit the same.
