Best lift for 2008 Powerstroke - Ford Powerstroke Diesel Forum
Old 04-09-2012, 03:48 AM
Question Best lift for 2008 Powerstroke
I have an 2008 Ford F250 6.4l and I was wondering what the best riding lift would be for it between 2.5" and 4"?
Old 04-09-2012, 08:46 AM
Depends on your goals and budget. If you just want the truck to be higher and tuck larger tires and enjoy the stiff ride from the factory, there are a ton of budget options out there. If you're looking to clean up the ride over stock and use your truck offroad, there is a whole other spectrum of performance susepnsion systems. Only limited by your uses and budget.
Old 04-09-2012, 09:18 AM
Feedback Score: 5 reviews
Best lifts will have true 4 link arms that will allow you to set additional Castor that these trucks need. The 4 lnk kits will ride much better as they don't bind like the stock arms and many replacement arms will.
We Sell Pure Performance and Icon kits..please PM me if I can get you additional info or pricing.
Cary
Old 04-09-2012, 09:32 AM
Cary, I have seen some trucks that have the following info in the users signature. Icon 4.5" w/TEI spacer for a total of 5.5" front. Is that a good setup? Then, what gets done in the rear to match up? One truck in particular had the above, then a 7" rear block w/traction bars???
Any thoughts on this - are traction blocks the same thing???
I like a slight rake, as I hate the ***-dragging look when hauling/towing...
On my truck I started with the readylift 2.5" kit, then did research once truck steered like chit. Added caster cams - all was good but accelerated ball joint wear IMHO. I bought the kit they have to go 3.5" for guys who had the 2.5" kit. It had the 1" spacer and drop brackets to acheive castor w/o the cams.
This truck will only be here for 1 -1.5 years, but I plan to have homework done for next one which will be in the range of a 6" lift w/37's.
Old 04-09-2012, 10:44 AM
Good yes..best no..you would need 4 link arms for that.
7" rear block..thats crazy unless it was a PMF with his traction bars.
I would rather do PMF traction blocks with arms or a lift spring- Deaver rear mini spring pack when a rear needs more than 4-5" of block..esp if towing.
Castor shims only get back to stock specs which are not adequate..you need 4.5* min.
Old 04-09-2012, 11:10 AM
I like the stock stance on an F350 which has approximately a 4" block. To lift the front 6", the back would have to come up 5-6" for my tastes...
Whats a ballpark difference in price between the ICON 4.5"+1" vs the 4 link (not a price quote, but a ballpark difference between the 2)...
How does the first acheive caster correction (a drop bracket or cams)?
What will the 4 link do for me (on road only but some towing so I dont need off-road type of contouring) that the first lift wouldnt?
Do these kits usually use a tapered block for driveshaft angle?
Do rear axles move in relation to being centered in the wheel well?
Old 04-09-2012, 03:27 PM
Std Icon Lift used a drop bracket, adding a Tie spacer would need Castor shims IMO..so maybe $250 for both vs 4 link arms at $1000+-
4 link arms allow correct Castor of 4.5*+ not what shims can get you. A lack of Castor is what causes poor return of the steering wheel when turning, wobbles and wandering.
Blocks Pure has the correct offset blocks, Icon doesn't offset the pins.
Old 04-10-2012, 11:17 AM
I Already have a Fabtech 6" with 37s but it just rides really rough, i'm not really concerned with the cost I am just lookin for the best riding 2-4.5" lift for mostly road use I was kinda thinking that a 4 link set up would be the smoothest ride and I was thinking of going with 35 tires on 20 rims. And I also was leaning towards the 4.5" because I am wanting to run dual 8" stacks and I want the truck to still be tall enough for them
Old 04-10-2012, 11:37 AM
Either a Pure performance or Icon 4 link with Bilsteins #5160-65's or Icons piggies..
IMO Pures coils are just a little softer than Icons..but either kit as above will ride better than what you have now.
PM me if I can get you prices-options..
Old 04-10-2012, 01:32 PM
Cary, while this thread is going, can you touch on coil overs? I've seen some nice trucks on forums with them - good/bad? Advantages/disadvantages?
Thanks,,,
Tags
2008, 6.4, lift kit, super duty, suspension
