Grinding/Rubbing when I turn all the way
My truck ('05, stock tires and suspension) has started making a grinding/rubbing noise that I can feel in the floorboards when I turn the steering wheel all the way. It's more noticeable when I turn left than when I turn right. Other than the dust seals on the axles that have popped off (haven't figured out how to reset them yet) I can't see anything wrong with the front end. I haven't been in a wreck or hit a large bump or anything else that could cause damage. Any ideas? Thanks for your help!
If it's like my 05 witch did this the tech said nothing could be grinding and took it back got it to do it for him it was my axle u-joint on my drivers side it was cracked in half and when under stress especially in 4x4 it would grind check them ujoints man
| Tags |
| grind, rub, steer, steering wheel, vibration |
