Loose front end
96 f-350 with a wondering front end and several inches of play in the wheel ,what are the most common elements that need to be replaced
My 02 seems to have the same problem. Interested to see replies. Mine has bill steins and an adjustable steering stabalizer bar thingy.
![]() Wishin I was fishin. |
steering gearbox and/or tie rods most likely gear box
Sound like maybe a few things are very worn out. I would jack it up and shake down the front end. Dont sound good.
Jack it up and get someone to articulate the steering wheel back and forth while watching underneath the front end.
Found out my problem. The bushing behind the drivers side hub went out today. It was all I could do to get it off the road. Luckily I was 1/4 mile from the dealership.
As stated above, most common culprit is the gearbox. tie-rod ends, drag link and track bar wear will cause some play, as will bad u-joints in the intermediate shaft. 90% of the time, play can be traced back to the gearbox. When mine takes a dump, I will be getting a redhead.
