Teach me about rear lift blocks. 2006 f350 - Ford Powerstroke Diesel Forum
Old 03-22-2012, 05:29 AM
2006 f350 with the factory helper spring. Do i want tapered or non tapered for a 5.5" block? Why does one site say won't fit with the overload spring? What does that have to do with it? I just looked at the truck and didn't think it would matter.
I was looking at the Tuff country 5.5" rear block kit.
DO most rear block kits not incorporate the factory bump stop?
Old 03-22-2012, 12:29 PM
the tapered blocks are to help adjust the pinion angle(to keep it level) don't think you will need them. and most blocks don't use the bump stops. unless you use a smaller one and put the factory one on top.. but there are some fabricated one's out there that do but are pretty high. if you go with blocks make sure you get some strong bolts and torque them to the right specs.
here's a link to one with them built in 5" 05-07 Ford F250/F350 Super Duty 4x4 Fabricated Lift Block Kit (w/ built in bump stops) @Top Gun Customz
here's one with out them. 99-11 Ford F250/F350 Super Duty 5" Steel Fabricated Lift Block Kit @Top Gun Customz
Old 03-22-2012, 08:24 PM
I decided to go with 6" icon vehicle dynamic blocks. Where can i get the u bolts/hardware since they don't come with them?
Old 03-22-2012, 08:51 PM
Top gun customs has them in a bunch of lengths. Just make sure you get the ones for a sd and torque them to the right spec drive it for a couple days then do it again.
Sent from my SCH-I500 using AutoGuide.com App
Old 03-24-2012, 04:15 AM
Will i have any issues doing just the 6" blocks and maybe longer shocks? The ICON blocks are flat, not tapered.
Old 03-25-2012, 08:53 AM
6" blocks are pretty tall. The bigger the blocks the more likely for bad axle wrap. I would consider getting 6" lift springs. And yes new shocks.
Old 03-25-2012, 10:06 AM
And/or some traction bars.
Old 03-26-2012, 09:32 AM
HUSKY SPRINGS, helper kits, u-bolts, Timbren Kits, Air Lift Kits
cheapest i found, plus they make custom lengths and they are hot dipped in oil to give them a protective coating. had my fronts ubolts for a year and they still look brand spankin new
