lift ??? - Ford Powerstroke Diesel Forum
Old 03-17-2012, 10:24 AM
lift ???
ok i have a 8inch rough country lift and it sits lower in rear i used there blocks instead of springs probably would have been better with springs . ? is ...is there any way to get the rear to sit up a little higher ??? its not off by much but you can notice it thanks
lift ???-img_20120317_141615.jpg   lift ???-img_20120317_141622.jpg   lift ???-img_20120317_141545.jpg
Old 03-17-2012, 11:21 AM
add another 1in block, add-a-leaf, or new springs
Old 03-17-2012, 11:26 AM
I thought it was bad to stack blocks? I took leafs out the 2 helper springs. Could I have left them in? Not sure on that
Old 03-17-2012, 11:36 AM
No very common mistake. most ppl assume stacking them is bad. say you have a 4" solid block its no better than 2 2" blocks. check out this thread there is a quote straight from icons web site about stacking blocks.
noob questions
Old 03-17-2012, 01:06 PM
yeah i dont see why not how big of a block did the kit come with?
Old 03-17-2012, 02:04 PM
add some blocks.... my 89 has a 6" lift but the rear end is all blocks (3 individual block welded together and to the rear end) has no problems
Old 03-17-2012, 04:13 PM
here is pic of lift block
Old 03-17-2012, 04:37 PM
I too recently bought a rc 8" kit with the block. My truck sat 4" lower in the rear. I called and complained but they said that my springs had sagged that much ( I said BS). When you take out a 3.5" block and replace it with a 7" block the truck only goes up 3.5" but the folks at RC couldn't understand that. I ended up getting RC 8" rear springs but the rear still sat 1.5" low. So I added a 1.5" block and all is well. Hope this helps.
Old 03-17-2012, 05:16 PM
I retract my previous statement. Didn't know it was a 6" Put an add a leaf in it that'll get you about 2" more and I have 2 installed on mine and they haven't really stiffened the ride up much. If you decide to stack them or get an 8" then I would invest in some traction bars.
Sent from my SCH-I500 using Tapatalk
