steering stablizer ??? - Ford Powerstroke Diesel Forum
Old 03-16-2012, 09:46 AM
I have a dual setup in the front with procomp es2000. I bought the truck with it already lifted and I noticed that the factory one is also still on. Does it make a difference if I take it off or leave it on? I know that my steering wheel is impossible to turn at a dead stop.
Old 03-16-2012, 11:15 AM
You can get rid of the stocker........I bet that is a bear to turn.
Old 03-16-2012, 12:14 PM
how do you remove the bolt that goes through the steering arm? Its in there real good.
Old 03-16-2012, 04:37 PM
Mine was aggrivating to get off as well pretty sure there a place in the shaft to get a wrench on it also. and if its that tight soak it in some wd-40, pb blast. or you could try heating it up. worse case cut it off.
Old 03-18-2012, 08:50 PM
well i finally got it off I had to pound on the trac bar right next to the bolt and it poped right off. It made a considerable difference. Its still pretty tight to turn but I can turn it now as opposed to before.
Old 03-18-2012, 09:00 PM
I know mine is a pain when sitting still. Looking into hydraulic assist. And I'm only running the factory stabilizer
Sent from my SCH-I500 using AutoGuide.com App
Old 03-18-2012, 09:22 PM
ive looked into a rock ram setup as well, but right now other mods come first.
Old 03-18-2012, 09:25 PM
Agreed. Cause they ain't cheap.
