Sway Bar Bracket Spacer
So I'm converting my 4" to a 6" lift.. The only current limiting factor will be keeping the sway bars in the correct geometry (keeping the arms parallel with the road). I already have the frame brackets flipped to the bottom of the frame. What will need to happen is the bracket be dropped 2-3" or a longer link is required. Seeings I have access to a milling machine, I've decided to make up a spacer for between the bracket and the frame. Does this seem like a good or bad idea to you guys?? Is this a common problem for anyone? If it is, I might make a decent size batch of these spacers, and would be willing to sell them out for very cheap, maybe put some on ebay for people like me who don't like buying a whole kit! Any input would be greatly appreciated!
do you know if it matters if they're tilted up? mine are at like 25 degrees i'd say, not too bad
Sent from my SCH-I500 using AutoGuide.com App |
