leaf vs coil springs
I have a 2002 F-350 4x4 with the leaf spring front suspension. I'm very interested in converting to the coil spring front suspension that the 05-07 year Super Duty trucks have. However, I'm hesitant to do the conversion because I've read that the coil spring suspensions are prone to "Death Wobble" whereas the leaf spring suspensions are not. Can someone explain why this is so?
Thanks, Ron |
Death wobble does happen on a coil sprung truck, but there is normally a reason for it. The route your going putting brand new oe parts on or good aftermarket parts like a track bar and steering stabilizer in conjunction with a good alignment typically wont see any symptoms.
If you do lift it make sure all the above things I mentioned are addressed as well as using E load rating tires. Having a soft compoound tire gives alot of oscillation through the tie rods making the steering wheel become shakey.. othing wrong with what your doing...Radius arm truck with a 7.3? Killer! |
anyway, if you do go to coils..... you want to get as much castor as possiable with either 5* castor shims or an adjustable 4 link kit, or a 3 link kit\ also must get the track bar and draglink parallel so that the raduis' arnt different causing bump steer and causing over correction and death wobble!!and having agood alignment, good tires, and keeping up maintance on all your joints. if you do it remember that the backspacing is differnt on 99-04 axles and 05-07 and 08-now axles. if you run an 05-07 axle up front you will need 2 inch spacers in the rear to match the offset. or run aftermarket wheels with different backspacing |
The Best ride possible is using a 4 link radius arm kit in lieu of the stock radius arms..as they bind. 4 link arms also allow additional castor to be added ..lack of Castor on the '05 up trucks is the main cause of wobble complaints.
We have helped many install '05 up axles and suspension in OBS, Excursions and 99-04's..we have everything needed. Cary |
Appreciate the responses, they really help. I figure a coil spring suspension is in my future.
Ron |
