Mini Pack or Shackles
I have a 6" spring lift and want more what would be better the shackles or mini pack.
im running a shackle leveling kit easy install and rides great about 2.5'' over stock in the front. theres no difference in anything really all it did was extend the shock a little bit so its riding closer to the top of the stroke now but no problems at all.
Just be careful there... your extending past what your lift parts are intended for... axle (carrier bearing if your a cc), sway bars, track bar, pitman arm, etc
i'm running a 4" and i actually just ordered the mini spring pack, but most parts are interchangable from 3-6" lifts, bigger than 6" geometry starts changing |
I think I will buy a adjustable track bar. I only want to do it because it has a big rake and i want it leveled
It should have an adjustable track bar if i'm not mistaken?? but that makes it easier, just messing with the front anyways
what kind of lift are we talking?? you should set up your sig so me and anyone else who's trying to help doesnt point you in a wrong direction for some reason!
welcome to the org btw |
