How to get 1'' Higher?
Hey guys, I have a XL model 2002 F250. In stock form it seemed pretty low to the ground. It is 4wd and I leveled it in the front with a add a leaf.
Recently I added some bigger tires and the tires rub a tad on the plastic inner liner when I am at full lock when I have my plow on. Is there any easy way to get about 1'' higher? The FX4 models and XLT models seem to be higher than my XL. Do they have lift blocks etc etc. Thanks for any help!
have you tried pulling the inner fenders back with some zip ties? if so you can pick up a set of longer shackles fairly cheap
Trim level (XL,XLT,Lariat) has no effect on ride height. There are several different spring codes that can make a difference, though. You could always add a 1" zero rate to the front if you only need an inch or so. |
It really isn't a good idea to add longer shackles without corresponding hangers.
This would be a much better route: http://offroaddesign.com/catalog/Zero%20Rates.htm |
