Got the CustomDiesels leveling kit installed.
thought id post up pics of my leveling kit 2.5" i just got on. Super easy to put on. Had to go buy new 6 ton jack stands. the 4 tons i had were screaming and flexing under the weight of the front end. only complaint i have is i think the kit shoulda come with new brake lines or maybe a longer bracket for them to allow a little more length...
oh and seems like they chatter a bit when going over a bumpy road. i think its cause there isnt an isolator between the new spacer and the frame mount.?? Before ![]() ![]() after ![]() during ![]() ![]()
i have never done a leveling kit on a 2011 but shouldnt the spacer go under the spring instead of above it?
that is how the lift on my 06 was with the spacer under then spring |
there are kits both ways. from what i read the spacer on the bottom creats to much stress on the spacer and bolt?? i dunno but i like this setup better. thing i dont like about this kit is there was no isolator between spacer and frame mount and is noisey. will have to make my own now...
I have a leveling kit that's been lying around for too long and I have some time next week to do it. It's the same setup that you have it I was wondering about installation. Do you simply jack the front of the truck up and put jack stands on the frame and then put the jack under the axle and lower it until the springs come down enough? It seems like there is more to it than that? Do you have to unbolt anything? And how long did it take you start to finish? Any other tips would be appreciated. Thanks.
raise axle back up and reconnect everything. pretty easy. i dunno which one you got but mine makes noise alot and custom diesel said i should use the rubber issolator between the spacer and frame. but i can cause issolator is formed for the spring and not flat on both sides... |
