Opinions: E99 level kit, looking for 3" or so.
I have a mini spring pack right now and they are only 2". I need to get the trackbar bracket or an adjustable track bar for the front and want to get another inch or so out of it to level the truck as right now the front is about 1" lower than the rear. Who makes or what is the best way to get 3" of lift up front? I have the bigger rear blocks that are almost 4" tall, so I just need the front up about 3" to make it level according to wheelwell height measurements. I was thinking of a 2" shackle kit and then maybe an add a leaf for the extra inch?? Just want some ideas on ways to get there with minimal effort/money of course.
Put a shorter block in the back or buy a 4~6 inch lift kit. I piddled around like you're doing, I bought two lifts and an add-a-leaf trying to "save money". You'll be money ahead by just getting it over with and buying a complete lift. 35s and a 6 inch lift will do you just fine.
Do a 2" shackle/hanger kit, then remove several of the plates of the mini spring pack.
I am running 3 of the included 5 leaves of the Zone Offroad mini spring pack plus a full-length add-a-leaf for a total 4" lift. I like the mini spring packs because you can fine tune lift height by adding or removing the individual plates. |
At 4" of front lift, you really need a trac bar drop bracket and a dropped steering arm. You can only extend that drag link so far before it is at its max, then you can't center your wheel and loose steering radius, I think it was to the left. |
I think my plan is to gather the parts slowly. I will leave the 2" spring pack, buy the 2" shackle drop kit with shocks from stealth, get a trackbar drop bracket for 4" lift and the pitman arm. That should put me at 4" up front and just a 1/4" or so above my rear blocks. This way I can leave the stock track bar until I want to buy an adjustable.
![]() 2. The purpose of the dropped trac bar bracket is to keep the trac bar parallel to the drag link. Using a dropped steering arm with an adjustbale trac bar on the OEM bracket will have the trac bar at a higher angle than the drag link. 3. DON'T STACK YOUR BLOCKS! Buy a proper sized block if the kit requires you to stack. It's not safe, I've seen them spit out. |
