replacing sway bar links..factory size or extended? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 01-07-2012, 05:37 PM Thread Starter
I need to replace the sway bar links on my truck. I have a 2.5" leveling kit. Following the instructions I just flipped the sway bar link mount on the frame over under the frame and used the factory sway bar links. Now I need to replace the links since the bushings are worn out and it is making a lot of noise. Should I buy factory sway bar links or extended links and put the mount back where it belongs?
If extended any good sources? Thanks,
Will
2004 F-350 Lariat Crew Cab FX4, Dark Grey, T3 Front and Rear replacement bumpers, Fumoto valve, Diamond plate running boards, Zoodad mod, Dieselsite coolant filter w/ ELC, Blue Spring Mod, LED cab lights, Edge Insight CS, SCT SF3, PHP FICM/ECM rollback, Sinister EGR Delete, 6.4 Banjo Bolts, ARP head Studs, Zone Offroad Leveling Kit, CCV Mod, Straight Exhaust, S&B intake, Atlas 40, 295/75R16 BFG,
fishmanwill is offline
post #2 of 2 Old 01-10-2012, 09:17 AM Thread Starter
I went ahead and replaced them with factory length ones. I found some replacement sway bar links at orielleys for $40 for both sides and they are lifetime warranty and have a grease zerk fitting for greasing the bushing.
Will
