Rear blocks and ubolts for my F350
here is my question, I have a 2.5" leveling kit and now I want to lift my rear end 1" to 1.5" taller than it is now (its an F350) what is my best bet to do that? get a 1.5" block and new ubolts and stack em or does someone make a block that is 1.5" taller with new bolts?
any vendors chime in please. |
Never stack blocks, measure your current blocks and of course get blocks that are 1" bigger. However quick question, do you offroad in the sand at all? I ask because of wheel hop/axle wrap, in which case you might want to look into add-a-leaf. Ready-lift I think has blocks that many of our vendors carry, usually quicker response to PM them
Also don't get too carried away with lifting the rear, as you'll need to start messing with the carrier bearing which will cause drive live vibrations.....just an FYI
Yes I'm on the beach all the time in the summer don't want to spend the money on traction bars really, do u think add a leads will help with the wheel hop? U think a 1" taller block would need new carrier bearing?
With my 08 dually, driving through the sand was just ridiculous. Removed the overload and installed some pro-comp traction bars, truck went from weak sauce to an absolute beast in the sand
I run a 6" Pro Comp spring lift in the rear, and I drive in some soft sand. It's not bad. By far the best thing I had in the sand so far was a set of 365/65 16 Toyos. At 14.5 wide, I didn't need 4hi much. But, they quit making them and I am on 315s using 4hi in the sand like its cool. While ladder bars would be cool, I do fine.
So do the add-a-leaf this year and the ladders after you buy yer new hut. If you go real tall remember that the carrier bearing needs a wedge to be lowered, NOT a block. I've seen guys use a block in their CB and grind it up. |
