ball joint ??
This spring i am going to do the ball joints and axel u joints on my truck. Is there anything else i should do while i am there? Axle seals? Dust seals? Thanks for any info.
![]() Also does anyone sell a kit with all the seals needed? |
Maxx lift sells a kit with every thing you need for the ball joints
. Thanks anyway!
Take a good look at your outer tie rod ends too. It's good to freshen those up when you're going that far.
i would fo new dust seals on the axle shafts into the hubs... and new vacuum seals for the hubs if you have them, and the o-rings on the hubs themselves... always a good idea to replace seals when you have it apart, expecially when it is so extensive to take it back apart
my list so far is:
ball joints axle u joints track bar ball joint inner bearing of wheel bearing hub,outer axle shaft bearing inner knuckle to axle seal axle shaft to axle housing dust seal Sound complete?? |
sound bout right... and dont forget the o ring on the hub...
arnt all the bearings in one big unit??? where they are all replaced together |
I think the o ring on the hub comes with the stuff i am ordering. I am not sure about the bearings. Does anyone know?? This part list came from a member that did an 05 ford
