OEM ride height - Ford Powerstroke Diesel Forum
Old 12-30-2011, 06:56 AM
OEM ride height
Ok, I have 2007 F-350 single rear wheel and four wheel drive. I have a ready lift level kit in the front for about 2 years now. When I installed it, the truck sat level. Now it seems to sit lower in the rear. The overload helper springs are almost touching the mounts with the truck empty. My question is, if I take the level kit out, do you think it would correct it? Or I could replace the springs, or I could add a leaf, or I could replace them with a spring pack with a larger carrying capacity. Any thoughts are appreciated. I'd like the truck to sit level or maybe just slightly higher in back. I'm not after a lift
Old 12-30-2011, 07:05 AM
Did your kit come with anything for the rear?
Every superduty that I have installed a leveling kit on (4x4 not 2x4) ended up being slightly higher in the front. The F-350's arent as bad. I think the cheapest route would be to replace your factory block w/ a aftermarket 4" w/ new u-bolts.
Or you could do a add-a-leaf or even better a mini spring pack that replaces your overload spring.
Old 12-30-2011, 07:24 AM
The blocks that are in my truck now look like they are 3.5" tall. I don't think a 4" block would be enough to correct the problem
Old 12-30-2011, 08:48 AM
And no, the ready lift kit for the front didnt come with anything for the rear.
Old 12-30-2011, 08:49 AM
F350s are usually dead level with a 2.5" front leveling kit. F250s are nose high since they come with a shorter rear block from the factory.
The problem at hand is that your main rear springs have fatigued and sagged - a common problem with Ford springs (leafs and coils). Hence why your overloads are almost touching the frame stops when empty.
An Add-a-leaf will bring the rear back up, but will also stiffen the ride when empty. Air bags would also bring the rear back up (and increase load handling in the rear) but would also increase the stiffness of the empty ride. A larger rear block would fix the "levelness" but doesn't really solve the problem - and it increases the potential for axle wrap.
The only true answer is new leaf packs - preferably aftermarket so that you don't have to repeat the process in the future.
Old 12-30-2011, 09:12 AM
Thanks. Thats kind of what I was thinking. That there must be a problem that caused the springs to sag. I priced a local company for new spring packs. They seemed reasonable. Do you have any suggestions of places to order or an aftermarket brand to look for? You say to try to stay away from putting Ford springs back in?
Old 12-30-2011, 03:30 PM
Ford springs are notorious for sagging. If you buy replacement Ford springs you will be doing this job again in the future. For those still under warranty, there's a Ford TSB out that essentially says if the sag is less than 2" on a given leaf spring, to insert shims between the spring and spacer block to restore the ride hight to level. Only if over 2" of sag do you get a new spring.
There are a number of leaf spring companies that offer Super Duty springs - both in OEM rating, and in heavy duty (increased spring rate) version. Try Husky Spring, SD Truck Springs, Stengel Bros. You will find the aftermarket spring prices to be comparable to OEM.
Good Luck
Old 01-02-2012, 08:24 AM
After looking online for a bit, General Spring in Kansas City seems to be cheapest. Anybody have any experience with them or any thoughts?
