banging sound from front wheel well
when i drive around if i hit a small bump i hear and feel a banging sound. has anyone had this issue?
What truck do you have? Do you have a lift? Come on we need more information.
its a 2003 f-250 6.0 with a leveling kit on it, as far as i know everything else is stock.
I would probably jack up that wheel and check the wheel bearings and ball joints first.
ok will do
Check the ball joints and sway bar link bushings.
i checked the ball joints and its not that, how do you check the sway bar link bushings. all answers are greatly appreciated.
See if there is play in them. Mine are shot and thats where all my banging came from.
no ther is no play in anything i checked everything. i think it may be my shock.
That is a good sign. So why do you think it is your shock? Is it loose?
Next step for me would be to throw a jack stand under each side of the axle and get the truck up in the air. Then grab and feel everything, turn the wheel , watch it. See what you can find. |
