New Leaf Spring Suggestions?
My truck is a '99 F250 7.3, it has nearly 312k miles on it and the drivers side sits almost 3 inches lower than the passenger side. I figured I would get this fixed before the snow season for my plow.
I often tow and do a little off-roading, this is a work truck so it see's some abuse. What do you think about these leaf springs? http://www.generalspringkc.com/index...1652&parent=82 It doesn't say it will sit any higher than stock so I'm assuming the plow mount would be fine and I wouldn't have to lower the plow mount? Any other suggestions/ ideas? Thanks guys, Andrew |
Bump, please help?
The link doesnt work for me
If you use your truck for work and are at stock height , just look for so oem leafs . Most all lift springs are good for lift and flex and not as much for payload. Ford has a xcode front spring they use for the snowplow package wich almost levels your front end. I bet you could find a set for nex to nothing. Ask so of the 4x4 shops .
