No Front Sway Bar Lifted Truck???
Anybody running a suspension lift 3in and up and remover the front sway bar? I have an 03 with an 8in lift thinking about ditching it just wondering any of you guys did it and if you noticed anything? Probably more of a question for you front leaf spring guys...
Ran mine long time without, flexed better, couldnt really tell any differance, I have seen a lot of lifted trucks without them. I think if you pulled an E-Brake slide on the highway, or rollover type situation it would come into play and maybe help prevent a rollover, but with a lifted truck you probably just flop over anyway. I may remove mine again, does allow more flex
Jet you have 8" lift? You ever have any issues pulling that 5er? How'd you truck pull without the sway bar up front?
I have no sway bars either. Have not had a chance to pull anything heavy yet.
If any of you remove them Ill take em. Sway bars are great for towing and hauling loads.
Too bad you were not a little closer... I have the big fatty ones off my truck front and rear...
dont think i ever towed without the front one, i dont have a rear, drove plenty without the front on, just did not not tow, im sure it would of been fine. Unloaded my truck leaned more in corners, but i have dual rate coils, only riding on a 275lb spring rate untill the first lock out so my trucks leans a lot in corners anyway. The sway bar keeps it from doing that, I didnt mind the lean though, and it definitely flexed easier without.
Thanks for all the post guys....i never had one in the rear and I tow a lot never noticed anything...probably just gonna ditch the front for sure now I have leafs in the front so not like its gonna flew that much and you right if you come close to rolling you are gonna roll anyways hahaha!
Try it out and see if you like it.
