Suspension Upgrade Options... - Ford Powerstroke Diesel Forum
post #1 of 1 Old 11-05-2011, 01:11 PM Thread Starter
I am in the market for some coil overs for my 08 6.4. It has a BDS 6in lift on it now with Rancho shocks front and rear. The front is starting to sag after having the lift on for about a year now. I'm wanting to get rid of the spring and shock setup on the front and just go with a coil over. For the rear on I am just looking for a better shock. I have read a lot about the King coil overs, but I'm not looking to put out that kind of money. They truck doesn't do any crazy off roading or anything like that. I dont pull any heavy loads to often, mostly just a 24" trailer with a couple bobcats and mowers.
I am just looking to get a better ride up front and get rid of the sag. I also like the look of the coil overs. However if you can educate me on a better spring/shock setup I may go with that. Just looking for some good options and also lengths I may need. Also if I could I would like to get a bolt on coil over setup, so I can do it myself. If you know of some good setups let me know. Thanks in advance.
__________________
2008 Ford F-350 CC/LB 4X4
Hoosierdiesel is offline
