Need info for Regear???
I’m going to be changing the gear ratio in my 2005 4x4 F-250 soon. Before I order the parts I wanted to double check and get verification on the axles. I will be changing to a 4.56 ratio. In the frond is a Dana 60 and in the rear is Sterling 10.5. So for the front I will need to order Dana 60 high pinion reverse cut gears with a larger carrier for the 4.56 and a master install kit. For the rear I will need to order Sterling 10.5 Low pinion standard cut gears with a larger carrier for the 4.56 and a master install kit. Can somebody help verify this? Thanks
Anybody???
