Question for those running a Newtons leveling kit.
I recently purchased a Newtons 2.5" front leveling kit for my 05 F250. I'm going to be using F350 rear blocks. I was hoping that somebody could give me the size of the carrier bearing spacer so I could fabricate one for my truck. Newton's front only kit does not come with the spacer.
Thanks |
You can buy a kit that comes with different sizes, of just get several pieces of shim stock. The general rule of thumb is 1/4" of shim for every inch of lift. If you still have shudder, you can make adjustments from there. Every truck is different, so it just takes some experimenting.
Here are the instructions for the ICON kit. Might help you out:
http://www.iconvehicledynamics.com/w.../Icon_3-37.pdf Check with Cary he can hook you up. Here is his contact info: http://www.powerstroke.org/forum/mem...ance-inc-.html
