I know some of you will find it strange, however, I purchased this truck and it has a 4" pro-comp lift with 36" tires. While it looks great, the main purpose of me purchasing this truck is to TOW. I realize I "can" tow with it the way it is, however, it's probably not going to be optimal nor do I feel like drawing unnecessary attention to myself getting bothered by the po-po :-)
So.... my friend and co-worker has an '04 F250 that he wants to lift and therefore, wants my setup. He will purchase the "leveling" kit which I believe is approx 2" , correct? I realize that I'll probably have to swap shocks with him but what else will need to be switched? The front bar? Torsion? Steering stabilizer? |
Wow lots of views and no response(s). :-(
if its a spring kit just springs, track bar if its aftermarket, shocks, pitman arm, sway bar links. maybe a few different items. no a hard job
Does that mean that I have to buy all new parts to replace these other ones?
nope. just trade your buddy.
Alright-if you have a 4" kit, here is a comprehensive list of what MUST be swapped from truck to truck.
sway bar end links-front and rear (if equipped) shocks track bar drop bracket (track bar as well if it anything other than OEM) Springs (rear may be a block lift, in which case blocks as well) bumpstops pitman arm carrier bearing shim (if you have a 2 piece driveshaft) Make sure you address brakelines, sometimes people just bend the brackets so they will fit, other times new lines are used. PM me if you have any questions. |
a 4" lift will not adversely affect your ability to tow. I actually found that my truck towed my enclosed a bit better lifted-it broke the wind before it hit the wall that is my trailer. I tow all the time and have 12" with 40" tires.
Unless there is something specific your lift is preventing you from doing, I'd leave it the way it is. |
I guess I can leave the lift on there just wasn't sure if it would have a huge negative impact (mpg, etc) with the lift. Then again I went from 36" tires to 34" tires so I bet that will help. |
If you drive it gently, slightly larger tires can actually help fuel economy by lowering cruise RPM's at a given speed. My last truck picked up 2mpg when I went from stock tires to 37" tires (It takes a lot of discipline, and you have to know what speed your truck is happiest at).
I think you'll be fine with the current setup. Just make sure your tires are E rated, and properly inflated. Post up some pictures of the new rig! |
