Power steering 2000 f250 7.3 4wd - Ford Powerstroke Diesel Forum
Old 10-13-2011, 07:38 AM
Last week on elk hunt blew power steering hose replaced hose and not knowing any better , I put power steering fluid in it. Now ive found out I need ATF. Did I screw it up? or will it be ok If i flush it out and replace it with ATF? And will a Return line flush method be enough? Please help
Old 10-13-2011, 08:20 AM
I am that hot
You should be able to drain it from the brake booster area and be ok, just flush alot of tranny fluid through it. I have flushed it a few times.
