Steering Stabilizer Help - Ford Powerstroke Diesel Forum
Old 09-21-2011, 11:36 AM
I bought a new stabilizer to replace my OEM unit, when I remove the bolt from the pin on the drag link the pin will not come out. Do I need a special tool or does it need a good beating? I lightly hit it with a hammer a few times but did not budge. I don't want to screw it up.
Not sure if it matters but I have an 08 F250.
Old 09-21-2011, 07:44 PM
From my experience, put a propane torch on it for a minute or so and then pop it with a hammer and it will come right out. Without the heat, it really doesn't want to move.
Adam
Old 09-22-2011, 05:28 AM
not to hijack your thread but which stablilizer did you go with? i am looking at a dual setup from top gun customz.
Old 09-22-2011, 06:46 AM
Adam
Thanks for the help.
Old 09-22-2011, 06:48 AM
I have the Rancho OEM replacement. I'm running stock tires so for now the dual setup is not needed.
Old 09-22-2011, 06:50 AM
i was also looking at that OEM replacement from rancho. I saw it at shock warehouse. I am also running stock tires. i just thought a dual would be better. Not so sure tho
