Will this work?
I want to put a 6 in lift on my pickup. I have a 99 F250 SC LB. I was wanting to put 37x13.5 Toyo MTs on 20x10 wheels, now here's the question: will these tires and wheels fit with these wheel specs
Backspace = 4.52 in Offset= -25 mm I just wanna also make sure the bolt pattern I need is 8 on 170. If this will not work, please give me any info needed to complete this modification. Another question: will I be able to keep my airbags? |
The BS is correct. 8x170 is correct.
Depending on how you lift the rear you can keep your bags..or mod them for lift springs.. |
How bout the offset? And can I clear 37x13.5?
Offset doesn't matter BS does or you will rub the springs. I would run a 8" lift.
