Reducing lift, reusing existing parts? - Ford Powerstroke Diesel Forum
Old 08-16-2011, 04:57 PM
Chapter Director
So here's the deal. I bought the truck with a total of 8.5" lift. A 6.5" lift kit with a 2" leveling kit on top of that. I want to drop it down to 4" lift so I found a deal on some 4" springs. So my question is can I get away with reusing the track bar drop bracket and drop pitman arm from the 6.5" lift? I mean the PO went up 2" using that same drop brackets so why can't I go down 2" from it? All the drop pitman arm and trackbar brackets I found were all 3-6" lift so does it really matter?
Just want to get it all sorted out and parts located before I start tearin into it.
Old 08-21-2011, 10:54 AM
Chapter Director
bump anyone? need to know im going to be picking up the springs this week probably
Old 08-24-2011, 01:11 PM
YOU PRABABLY CAN REUSE THE DROP PARTS JUST MAKE SURE YOU SHORTEN YOUR TRACK BAR UP AND MAKE SURE YOUR DRAG LINK AND TRACK BAR ARE ON THE SAME PLANE.THEY SHOULD BE LEVEL OR A LITTLE BIT UP.
Old 08-24-2011, 02:00 PM
you going to be selling the old springs?
Old 08-28-2011, 04:48 PM
Chapter Director
yes i will ive got 6.5" springs in the front and 5" springs in the rear i can sell the whole set all four for $450, plus shipping unless you want to drive up to nor cal, i just need to locate a set of stock rear springs first
ended up pickin up the new front springs today, now i need an adjustable track bar and i can swap the front parts
and another ? for the truck to sit level with 4" up front would an add a leaf be enough? ive got the f250 stock 2.5" block
