Ball Joint Help, ASAP TRUCK IN SHOP - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-04-2011, 04:59 PM Thread Starter
sbarbee54's Avatar
Exclamation Ball Joint Help, ASAP TRUCK IN SHOP
I purchased some Moog ball joints through a online vendor I have used before turns out they were the wrong ones, and he does not know what ones to re order for me. I need to see if someone knows the actual part #'s for the upper and jower ball joints from moog for a 05 F250 6.0L diesel FX4 4WD 4 door..... I bought the 80027 and 80028 but they are not right, also he gave me the wrong pitman parts for inner and outer, help with those would be great too. Or even another brand that is greasable. Truck is sitting in a shop right now
sbarbee54 is offline
post #2 of 6 Old 08-04-2011, 05:12 PM
Powerstroke Techie
justinmix's Avatar
Sounds like he sent you 2 upper joints. Think those are for a 2 wd truck. The upper is a Moog 80026, and the lower is a K8607T I believe. I pulled this info off the Advance Auto parts website. Personally I'd just have gotten them thru an auto parts store then mess with the online crap. Hope you got a hell of a deal.
Here's the links to where I found the info....
Upper.....
Buy Moog Ball Joint K80026 at Advance Auto Parts
And the lower.....
Buy Moog Ball Joint K8607T at Advance Auto Parts
justinmix is offline
post #3 of 6 Old 08-04-2011, 05:30 PM Thread Starter
sbarbee54's Avatar
I wanted to but they were all 2 weeks out had none in stock, any ideas on the tie rods, I keep getting mixed results because allot of them do not specify for 2wd or 4wd
post #4 of 6 Old 08-04-2011, 05:34 PM
Powerstroke Techie
justinmix's Avatar
Wow, you must have some crappy parts stores around you! I usually use the better grade ball joints from napa and they keep them in stock.
Exactly which ends are you trying to get? The outer tie rods near the spindles? Or do you need drag link ends? The drag link is the rod coming from the steering box, the tie rods are the ones uses to tie the front spindles together.
post #5 of 6 Old 08-04-2011, 05:42 PM Thread Starter
sbarbee54's Avatar
I am looking to do all the outter drag link end and the inner ones as well
post #6 of 6 Old 08-04-2011, 05:52 PM
Powerstroke Techie
justinmix's Avatar
Hmm, still not sure what you're talking about. Ok, were going to call the rod that goes from the steering box down to the tie rod the drag link. The drag link has to joints in it, an outer and an inner. Here's a napa link for that part. https://www.napaonline.com/Catalog/R...+50028+2028071
The other rod that goes from spindle to spindle is the tie rod. Here's the napa link for them. https://www.napaonline.com/Catalog/R...+50028+2028071
It can be very confusing trying to figure out what you need. Best thing to do is get ahold of someone who understands what you need, or try and match up something from the parts pics. Good luck!
