not sure if shocks are correct
i bought a used lift i was told it was a 6.5 pro comp lift not sure if it is a pro comp or not. but my problem is the shocks are no good on the truck so i took them off and measured both the front and rear and they are both 34" long fully extended now are those the right shocks or what
What matters is whats the measurement from the mounting bolts with the truck on the ground..with that info I can get you Bilsteins if wanted.
You need aprox 4" droop-extension installed.. |
25 in the front and 31 in the back. could be an inch either way and how much for the bilsteins and what do you mean a 4" drop extension
Bilsteins would be short in the rear so its either relocate the bracket higher, or use more expensive shocks.. like Pure performance 2.0 customs..PM coming.
