8" Icon lift what size rear block should I run ?? - Ford Powerstroke Diesel Forum
Old 07-12-2011, 03:13 PM
08 f250 Im going with 7" Icon springs with TEI spacer to total 8" lift up front I have a 6" rear Icon blocks will the truck sit level or will I need a bigger block ???
Thanks
Rick
Old 07-12-2011, 03:21 PM
Send a message via AIM to eric.davis
I ran a 9" OUO traction block with my 8" lift and thought it sat just right.
Old 07-12-2011, 03:44 PM
Looks pretty level there ! my question is why doesn icon give you a 6" rear block with there 7" lift kit if its not gna sit level ??? I was thinking i was just gna need another 1" since im adding the TEI spacer lol
Old 07-12-2011, 04:38 PM
Well with that 6" block is it stacked on the factory block? Because then that would make sense to me for a total of 8" of block with 7" lift
Old 07-12-2011, 06:47 PM
Not sure from my understanding you should never stack blocks
Old 07-13-2011, 02:32 AM
Almost every kit out there you stack blocks unless you upgrade
Old 07-13-2011, 04:10 AM
I have the 7" ICON. I had a 6" OUO block stacked with the factory 2". This had the rear .5" higher. I wanted a solid block and the rear to be a little lower so ordered a 7" PMF block and it now sits a .5" lower and looks much better. You will need an 8.5" block if you want it dead level. Trevor at PMF can make you one. Also, if you have a tune or tow pretty heavy you need to get traction blocks for anything bigger than 6". I don't have them, but I also have a stock motor and don't run the truck hard or tow heavy.
