Question about leaf springs
I just bought a '00 F250 and my right rear leaf spring snapped. My truck has a 6" lift on it, and my question is..
When I get new springs for the rear, do I need to find special ones because of the lift or will any old fitting leaf spring do? |
does your lift use blocks for the rear, or does it have lift springs? If it uses blocks, any spring will do. If it is a lift spring, you need to replace both sides to ensure it sits properly-used springs tend to sag-one new spring, and one used will cause issues (unless you find a matching used lift spring, which I doubt). Id consider a set of deaver rear springs with a 6" lift. They ride better than OEM.
If it's not the main leaf that is broken, you can have a spring shop make you a new leaf. Pictures? |
It depends on how your lift acheives its lift. It it is all done through a spacer block, which I doubt it is, then you can just get a factory setup. But probably since it is that much lift then it has a non factory leaf setup. But a good spring shop can make you a new spring pack to your dimensions. If it is a middle leaf then you could just get a single leaf and not get a whole spring pack.
Edit: I should learn to refresh before I post
| Tags |
| leaf spring, suspension |
