38/15.50/18's with 8.5" lift What backspacing? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-08-2011, 09:30 PM Thread Starter
stokingmyinches's Avatar
Im putting my lift package together and need a little help with wheels. Truck is a 04 f250, I'm buying a 8.5" lift and 38/15.50/18's. What backspacing will I need? most of the wheels I found are 18x9 and backspacing is available from 4.5" to 5.75". Will a -12mm offset/4.5" backspace work? Thanks in advance
stokingmyinches is offline
post #2 of 7 Old 07-08-2011, 09:36 PM
dazdillenger's Avatar
Feedback Score: 7 reviews
Yes, a 4.5 backspace with that offset will work. Will stick out a little farther than stock.
2005 Lariat CCSB F-350 SRW
300,000 miles and going strong
Exterior
12" fabtech lift with 40" Xterrain's on M/T classic locks, Adjustable track bar, Bilstein 7100 reservoir shocks
Performance
Edge juice/attitude CTS, SCT with ID tunes, Snow meth. injection, Diamond eye 4" exhaust, 03 turbo, ARP studs, Sinister coolant filter
Interior
2010 stone seats/console, pioneer avic d3 with backup camera/bluetooth
Misc.
Viair 450c compressor, dual 2.5 gallon tanks, air horns rated @115db
dazdillenger is offline
post #3 of 7 Old 07-08-2011, 09:53 PM
doubledrop's Avatar
I would think you need a wider wheel for a 15.50 wide tire. I know my toyos a 12" wheel is recommended.. im sure an 18 a minimum you would want is a 10" wide wheel
__________________________________________________ ______________________________
doubledrop is offline
post #4 of 7 Old 07-08-2011, 09:54 PM
Yes, a 9" wheel for a 15.5" tire will not be optimal. I'd get AT LEAST a 10, preferably a 12" wide wheel.
Exterior
Performance
Interior
Misc.
post #5 of 7 Old 07-09-2011, 06:15 AM Thread Starter
Ok, I guess I'll be going with a 18x10. Will a 18x10 -24 offset work? I cant find the backspacing specs listed anywhere but if I calculate it right it would only be 4.0" Will I need more the 4.0" of backspacing? Wheels I want are Moto metal 961's
post #6 of 7 Old 07-11-2011, 11:49 AM Thread Starter
Ok, I found out what the true backspacing on the wheels are, its 4.5". Will these work? Again they are 18x10 -24 offset and I'm running 38x15.50x18's on a 8.5" lift. Getting ready to pull the trigger on the wheels but want to be sure they will work. Thanks
post #7 of 7 Old 07-11-2011, 12:32 PM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
4.5" is what a OBS or 99-04 requires min, less is ok, more will rub the springs. But with 15.5 wide they will still rub the springs..
CT Performance, Inc. is offline
