Coilover help please - Ford Powerstroke Diesel Forum
Old 06-27-2011, 01:26 PM
Guys with coilovers i have a couple questions for you?
Do your coilovers rub? Meaning does the coil hit the shock and rub on it while driving making noises? Mine seem to be getting worse and worse and i am not sure how to fix it.
They even sound as if they are popping now and making really funny noises. I have no idea what is going on but it is driving me nuts.
Thanks for any help!
Old 06-27-2011, 06:27 PM
if you have a single spring they shouldnt rub the shock body. If you have dual rates the spacer between the different springs will rub the shock body and make some noise. If its that noticeable you can probably see where its rubbing via it scratching the shock body. spring might be bent or off the bottom plate, ie not sitting flat.
Old 06-28-2011, 04:10 PM
No, mine don't rub.
Old 06-29-2011, 05:34 AM
Originally Posted by HOTWHEELS34 View Post
No, mine don't rub.
Are yours a dual rate spring? Hmmm yeah both mine ad a buddy of mines do and we can't figure out what the issues is.
Old 06-29-2011, 01:07 PM
Yeah I have dual rate springs.
Old 06-29-2011, 02:07 PM
Well wtf is the deal with mine then. This is startin to bug me.
Old 07-02-2011, 04:51 PM
its probably the 4 link joints making the noise.grease them up real good and the noise will go away.I thought it was the springs popping also,turn out to be the joints needed to be greased.
Old 07-08-2011, 03:13 PM
You ever get this figured out? Got any pics?
Old 07-13-2011, 10:13 AM
I think it is my 4 link arms that need to be greased real good. I may have to take them off and grease them then put them back on to make sure i get everyhting in there good.
I would try this but my truck has been at the dealer for almost 2 weeks now.
