should i get hangers or new springs? please advise - Ford Powerstroke Diesel Forum
post #1 of 8 Old 06-26-2011, 11:09 PM Thread Starter
jerod187's Avatar
hey guys i have a 2000 f250 powerstroke, i did 2 add a leafs in the front which raised it 3| then i put 5" blocks in the back and it sits 3" higher in the back now so should i get some 2-3" hangers and shackles or get new leafs?
and if i bring the front end up another 2-3" what size lift do i have roughly? like a 4" or more of a 6"
jerod187 is offline
post #2 of 8 Old 06-27-2011, 05:49 PM
Let's go B's!!!!
Southpaw's Avatar
Feedback Score: 5 reviews
Keep in mind, if you start going any higher in the front than you already have gone, then you are going to need to change more front end components than just your springs. I.E. Tracbar, pitman arm, shocks, swaybar end links, etc...
IMO I would buy a 4" or 6" kit for the truck that includes everything you need instead of piecing something together.
Chris
2002 Crew Cab Long Bed
4" BDS, 35x13.50 Cooper STT on 20x10 Black Rockstars, and other stuff.....310,000 miles and counting...
2 Thessalonians 3 v.6-15
Southpaw is offline
post #3 of 8 Old 06-27-2011, 09:47 PM Thread Starter
jerod187's Avatar
hmm i think i may just go ahead and order shackles and sway bar end links how long of ones should i get 3-4 or 4-6"? trac bar drop brackets, longer shocks etc itll put me around the 300-400 mark plus shipping
jerod187 is offline
post #4 of 8 Old 06-28-2011, 09:37 AM
Let's go B's!!!!
Southpaw's Avatar
Get the the 3-4" ones. If they aren't long enough you can always just flip the factory bracket under the frame rail.
Chris
Southpaw is offline
post #5 of 8 Old 06-28-2011, 10:20 AM Thread Starter
jerod187's Avatar
Ok cool thanks a lot for the replys man, if you don mind I have a couiple more questions, umm so off TGC I'm gnna get the 2" shackles and is there any reason they won't give a full 2" lift? Also I'm gonna order the trac bar brcket, sway bar links, and drop pitman arm is there anything else you'd think I would need?
jerod187 is offline
post #6 of 8 Old 06-28-2011, 10:31 AM
Let's go B's!!!!
Southpaw's Avatar
Shocks for sure.
Possibly extended brake lines. Although probably wont need those, but you won't know until you get into it.
Chris
Southpaw is offline
post #7 of 8 Old 06-28-2011, 11:10 AM
Quoted: 3 Post(s)
I'd get a complete kit if you want the truck to have a good ride quality..and everything needed for a 6" kit.
CT Performance, Inc. is offline
post #8 of 8 Old 06-28-2011, 11:16 AM Thread Starter
jerod187's Avatar
Ya I understand what u mean but what's the difference if I buy every thing seperately?? Cuz it'll be a lot cheaper if I buy things seperate cuz I jus need to lvl the frt out and all the steering components?
jerod187 is offline
