Wobble on front end - Ford Powerstroke Diesel Forum
Old 06-20-2011, 01:52 PM
Wobble on front end
I have a 2001 F350 drw that has developed a wobble when hitting a bump on the right side. Left side is fine and it dosen't do it no matter what you hit. Even when driving down a bumpy road everything is fine. Only does it when the right tire hits a bump. Any Suggestions?
Old 06-20-2011, 02:15 PM
go to the 1:00 min mark and on, my 06 had "deathwobble" I put new tires on and it stopped
Old 06-20-2011, 03:29 PM
Check to make sure your track arm bolts are tight.
Old 06-23-2011, 01:53 PM
Thanks for the help. Problem was the Left front tie rod end and a drivers side tire that was about to seperate.
Old 06-23-2011, 04:27 PM
That deathwobble is scary sh*t , quite a relief when it's gone
Old 06-23-2011, 05:13 PM
Are there any aftermarket tie-rod ends that are heavier duty then the stock ones? I do a lot of back road driving with my '05 Excursion (live axle front end not coil) and I end up replacing them every two years.
