3"/3.5' LIFT
Ok i ordered my Ready lift sst 3 Front 3.5 rear, After i do the lift and tires, I need to do the alignment correct, Is there anything that i need to tell them or should they know what to do if they are as good as they say they are? or any thing i need to be aware of before installing, during install & after install.???? With the lift? anyone else do a 3.5 lift on there 08?
When I put my RC 3 on I had to get an alignment. You will notice your steering wheel is off center. It was a pain in the ***. On the other hand I have herd good thing about the Ready lift.. Post pics when you are done.
Yea i Know an alignment is coming, just worried about how it will drive when i'm done, I'll try to get before and after photos, but i may wait a month or so. So i can keep my warranty & get my tires. Figured i order the kit now while i had the $$$ Now i can save up for tires
I would not put it on till you had the tires.
I'M NOT, or i'll put the lift on drive to put tires on, and than straight to the alignment shop. Its nice when my other ride is a 99 7.3 with 5.5" lift straight 4" pipe So i can run around in that thing While i do all that if need be
Yes that helps.
Now my biggest decsion, What tires....... i know I'm going 33x12.50 an keeping my factory rims FOR NOW. I like the Nitto Trail??? I just need to start calling around to see what is ava. Are you in Afghanistan Right now???
