Help. My leveling kit isn't level. - Ford Powerstroke Diesel Forum
Old 05-22-2011, 09:22 PM
I have a 2005 CCSB. I bought the 2.5in readylift leveling kit. The back end is a little lower. I've read the F350 blocks will fix this but my truck is the Camper Special truck and the block placement is a little different. So my question is this. Will the F350 Blocks fix my problem or will I have to get some from an F350 Camper Special truck? Part Numbers would always be helpful too. thanks
Old 05-23-2011, 03:41 AM
I had the same problem myself. I wound up getting 350 blocks from ready-lift made for the camper special trucks. I believe it's the same block with just a longer u-bolt, but don't know that for a fact, as I havent visually compared them with normal F350 blocks. If you go that route, be advised it's a tapered block. I havent seen or felt any ill effects from it but just something to consider. Trevor @ PMF has some nice looking blocks; you might PM him for some info.
And yes, the F350 blocks will make your truck look right again. Mine measured out level with the 2.5" spacer but looked low in the rear. A 2" spacer would be the magic number for F250's.
Old 05-23-2011, 04:02 AM
thanks for the quick reply. i bought that kit but fear the install will return a rake. whats the problems with the tapered blocks?
Old 05-23-2011, 09:04 AM
Feedback Score: 5 reviews
Tapered blocks are for trucks with out a carrier bearing.
