Trying to get concrete experiences: Wheel Backspacing, 4" lifts, 37" tires - Ford Powerstroke Diesel Forum
Old 12-14-2010, 05:27 AM
All,
I've searched the board for the past couple of days (the 'net as well), and as usual I've come up with a multitude of contradictions.
Im looking at either the Rubicon Express 4" or the Procomp 4" (All spring) lifts. While I fully understand that 35" tires will fit - I've seen some people supposedly fitting 37" tires w/o 'rubbing'. Yet others saying that it cannot be done....So my questions are:
For those who have done it:
-What did you have to trim (If anything)
-What is your specific wheel/tire setup. Rim Size/Width, Tire Size, and Backspacing
For those who say it cannot be done:
-Have you tried yourself ?
-If so, where was it rubbing ? This is most important, as rubbing on the springs maybe cured with the proper backspacing....
Thanks,
Steve
Old 12-14-2010, 05:32 AM
Feedback Score: 5 reviews
I guess I'll weigh in here. I've got a 6.5 Pro Comp lift on my truck. 35x12.50R20's on 20x10's with a -25 offset. When I turn, my tires miss the lower front valence by about 1/2". 37's would definitely rub on my truck if I didn't trim anything I do not rub the springs with my setup...
Old 12-14-2010, 04:06 PM
a 4" lift with a 9" wide wheel and 4.5" backspacing with a 37x12.50 tire should not rub. I did the setup on my buddies truck and did not have to trim anything, and it does not rub the leaf springs.
Old 12-14-2010, 04:16 PM
37x13.50s on 16x9 4.5 bs hit the leaf springs. its annoying but I'm pretty much used to it.
Old 12-15-2010, 05:14 AM
Thanks guys. The wheels I was looking at were actually 4.75" back-spacing; so that should give me a little more room...
How about some pics ?
