yet another leveling kit question - Ford Powerstroke Diesel Forum
Old 12-12-2010, 05:55 AM
i have an 04 f250 4x4, i plan on making the spring pack to level the front, my question is how high could i go before i start needing a drop pitman arm or track bar etc. also whats the biggest tire i could fit under there after the leveling kit
any info helps thanks guys
Old 12-12-2010, 06:20 AM
At a 4" lift is where you need a pitman arm, etc..
With the leveling kits I do recommend using an adjustable trac bar though.
Depending on what tire and wheel combo you go with, you could run a 33-35" tall tire. I wouldn't recommend a 35/12.50 on 10" wide wheels with only a leveling kit though.
Old 12-12-2010, 06:35 AM
so i should be fine going 3" just with adjustable trac bar
Old 12-13-2010, 09:13 AM
Yep. That is assuming you are getting a setup with new shocks up front as well.
