any fords come from the factory with a high steer dana 60? - Ford Powerstroke Diesel Forum
Old 12-10-2010, 06:51 PM
Question any fords come from the factory with a high steer dana 60?
my truck is a 94 f350 drw that was converted to 4wd in 94 by advanced four wheel drive systems. the front axle in the truck is a king pin dana 60 with a high steer set up. drag link runs from the box to the right knuckle above the spring and the tie rod connects both knuckles under the spring. it needs some front end work and i dont know where to get the ends/draglink. i tried contacting advanced and havent gotten an answer yet. anyone have any info for me?
Old 12-15-2010, 07:05 AM
Lbs Lbs is offline
The 78-79 F350's were HP D60's, I had one for my Z71. They're pretty hard to find as a lot of people use them for SAS's on many vehicles.
Old 12-16-2010, 06:01 AM
it is a high pinion. i was under the impression it was out of an 86-91 but they did not have this linkage set up. ill have to stop at napa and see if they have a pic or something of the 78 f350 set up. heres what mine looks like:
any fords come from the factory with a high steer dana 60?-stuff-002.jpg   any fords come from the factory with a high steer dana 60?-stuff-005.jpg   any fords come from the factory with a high steer dana 60?-stuff-007.jpg   any fords come from the factory with a high steer dana 60?-stuff-003.jpg
